Why does starting with the clutch lever pulled in only enough to let the starter engage make starting easier on the sprag ? Just out of interest, thanks
The additional drag of the transmission helps smooth the pulses of compression on the crank which helps the sprag stay engaged.
That's my theory, anyway.
Reactions: Nicklemouse
I agree with Ed. The sprag needs to have some load on it in order to remain engaged throughout the start sequence of the bike.
If the engine "free-wheels" or moves enough to take load off the sprage, the sprag disengages and re-engages rapidly under load and that is the damage mechanism.
Eventually, it wears out.
