21 - 28 of 28 Posts
I had tight terminals on my old '14 Brutalé that did the same thing to me. There was just enough corrosion between the battery connectors it would carbon up and lose continuity under the load from the starter.
Yeah this was one of the first things I did. No change. Thanks
Check both temp sensors rad and block, sounds like one is faulty, common 3 cyl issue, same symptoms, I’ve recently diagnosed mine and waiting for the new part. Easy fix 👍
Any progress?
Patience of a Saint Chuck! o_O
Mine had a loose solenoid connection, not battery, but also had a bad sprag. With both rectified no problems starting. I guess what I'm trying to say is if your battery is good and connections are good between solenoid starter and battery, then blame the sprag.
21 - 28 of 28 Posts
