1 - 13 of 13 Posts
After another Thread (wont turn off) I started I have decided my SPU is most likely shot. I took it off this evening and noticed the dreaded green fuzz (corrosion) cominf from under one of the plugs.
Upon Closer examination I find the Saab name on the unit. Does anyone know if Saab was comissioned to build the SPU or do they use it on one of their vehicles?
i was lead to beleave that they were built by mitsabushi the same thats in the L300 and
BT50
The original SPU's were designed by SAAB and as most of us know, the Brutale's from 2004-2007 can be prone to failure - however, I've wrote this many times on the forum - once the SPU has been replaced, there have been zero recorded second failures.
As hb88xx said the only Saab part in the SPU is one of the connector blocks. I have been down this rabbit hole myself a few years back. If the old SPU is playing up buy teh new replacement part, had my fitted a while now and no more problems
jimboF4
jimboF4
And the new SPU replacement part is found where?
kiwidoc good game last night
an mv dealer in the uk told thats all i can say about it
Part number of new SPU is MV8A00A9615.
jimboF4
jimboF4
Thank you Jimbo. I noticed the newest forum sponsor, STAR TWIN, has a keen price on a new one. I'll look further into it....
jimboF4
8000A9615 (First serie B4-750 till no. #004321)
8000A9300 (B4-750 frame no. #004322 and later and all B4-910/989/1078)
8A00A9615 replacement for 8000A9615 (A and 0 difference!)
8A00A9300 replacement for 8000A9300 (A and 0 difference!)
You may/can use 8A00A9300 for first serie B4-750 (modification needed of cabling! but is no official writing. The other way around is not possible.
hb88xx,
Great piece of info there with the range of part numbers and replacements.
Makes sense to me as the wife's brutale was an early 750 model.
Now highly modified and has a 910 engine.
jimboF4
1 - 13 of 13 Posts
