Hello everyone,
I have a few questions for you guys, I have 2002 F4 and want to upgrade rear Sachs shock, I purchased used rear Sachs shock which is from 2008 MV Agusta Brutale 910; first question, will this rear shock fit on my bike, second prior to replace the rear shock (08 910 Sachs), I want to make sure spring rate is right for my weight. I weigh 225lb (full gear). If 08 910 Sachs rear shock is under weigh for my weight, I want to replace it with Ohlins spring, if you know of part number for ohlins spring could you let me know. I found one used at ebay; Ohlins TTX36 Shock spring 21040-36/105, can I use this spring on 08 910 Sach's?
Many thanks in advance!
