How many sprags you had?
  • Total voters
    61
1 - 20 of 55 Posts
How many sprags, including the original, has your bike had?
Also how many miles they lasted?
E.g. Mine is on original, and has done 3100miles - so I, so far, average 3100miles per sprag.
I wonder how many sprag issues are sprag - I.e. Have the noise as well, and how many are poor battery related? Mine always starts first time if been on charge or had a long run, but if had a short (5mins) run, it might only start second time.
Approximately the same milage as you, still on original.
You should add the displacement too.
My bike is a June 2012 build date F3 675. The sprag was replaced in October 2014 after only about 12,000 km's (7500 miles).
2013 F3 675....3200 miles still on original
2014 B3 800....3400 miles and still on original
23000km, 3, included original.
Miss the option zero replacement
If you've used 3 including the original why does a 3 not show up in the poll yet?
That would be 1, the original part.
Hey, don't look at me. I didn't make up the poll, just following the rules.
heheheh, yes... I understood.
But that does not make sense unless there were bikes delivered without sprags LOL!
Because I forgot the original one ?
4000 miles and original. Decent battery and properly adjusted throttle bodies help I'm sure. Hadn't touched it for 2 months recently and it started literally within a second of the first prod.
2012 675 F3 15500 miles until valve drop, on original sprag. I conclude the valves are weaker than the sprag.
Original, over 15,000km and no hint of any noise. Bike's never started in gear n clutch in, only ever when in neutral if that makes any difference.
800 dragster RR
6500 miles
never on a tender
sprag still original never had a problem starting
August 2013, B800, on Sprag number four including original, number five on order,
2014 B3 800. Had 1 replacement at 2500 miles. New one has clacked a couple of times but seems to be behaving now. 5000 miles on bike.
1 - 20 of 55 Posts
