1 - 2 of 2 Posts
08 312RR. I was cruising down the road, in 3rd at about 4k rpm and I look at the speedo and it´s reading zero. I checked both conectors next to the sproket cover and everything looks ok. I umplugged them and put them back together but the speedo just wonk work. any tip on this one?
Nico;
check the pickup, you should see a varying voltage signal from the wires coming from the sending unit when you turn the back wheel
since you are seeing zero the dash is functioning, but its not getting a signal from the sending unit
1 - 2 of 2 Posts
