G'day,
On a run with the boys today and about 100k's in the speedo started displaying any digits it chose every half second. Trip meters, odometer and time not affected.
Would I be right to assume the speed sensor inside the front sprocket cover is stuffed or is it something in the dash?
Deano
Revhead,
Found it. My fault as I didn't pay enough attention to the wire route from the sensor after I replaced the selector spring. Chain wore through one of the wires so there was the bad connection. A bit of soldering and more attention this time and all's good.
Deano
