1 - 3 of 3 Posts
Hi
Anybody know the correct spark plug for a MV 125TRL?
I took out a Champion L86.
I am going to put in a NGK if possible.
Thanks Keith
NGK B7HS with a 0.5mm gap.
Dorian
Forgot to say;
If it's the early type engine it might be a B8ES. Slightly diff heat range and a longer reach thread.
'E' Reach = 19mm long
'H' Reach = 12.7 mm long.
Just double check the depth of thread in the cylinder head. You can never be sure what someone might have fitted over the years.
Thanks Dorian
The Champion one which came out is the 12.7mm, but i will check the thread length of the cylinder head.
Keith
1 - 3 of 3 Posts
