1 - 6 of 6 Posts
Hi all,
I can move the sprocket 1 or 2 mm sideways to and from the driving flange on my f3. Is this normal? Any ideas what might be wrong? I have only done 2000 miles on the bike
thanks!
That's quite normal.You don't want any rotational movement at all.
Hi all,
thanks!
Same problem over here Logusta, changed the rubbers (under warranty) within 2500 km's. Last time the mechanic made a modification to the flange and there is no movement since. His idea seems to work, lets hope MV finds a definite solution.......
ive got a new dragster 800rr with 180 miles onit and just looked at mine and its got slight movement foward and back in the direction of the chain ,is this normal ???
he asks if its normal to have play , and you says its quiet normal ?
1 - 6 of 6 Posts
