Do Sidi boots run small or large from the standard US size. I wear a 10 in most shoes and a 9.5 in others. What size of Sidi boot should I get? I am getting a pair of the Vertigo Corsa and will not be able to try them on so I have to order and would like to get it right on the first try.
Thanks Andrew
I have Sidis...I wear 10.5 or 11.0 sized shoes, depending on the maker, but I went up to a 12.5 (US) in my Sidis. I could have gone to a 12, but I do like to wear thicker socks so the extra half size is perfect. I'd go up 1 size, or 1.5 if you are into thicker socks.
Griff
twoeleven
i'm uk 10 normally but can also get away with 9.5 uk
i wear sidi boots and there 44 european or 10 uk size
there very adjustable and i can't fault them
i would only go .5 size bigger at max
so you'll be a size 10.5 allowing for commfy socks
hope this helps sorry not sure on us sizes but take a look at sidi's web site for sizing
jas
Thanks Andrew
You should try to get boots that are as tight as possible without being uncomfortable. New Sidis take a few times to "wear in", particularly the leather and Lorica models. I would not get anything bigger than a 10.5 if I were you, as I saw a pair of boots fly off a guy as he was low siding his bike during a track day. Hope this helps. :)
I usually wear a size 10.5 US, my Sidi's are 45 and fit perfectly.
