1 - 13 of 13 Posts
looking for a longer side stand does anyone know were i can one DC do one but not paying that price.
your thoughts.
Buy a spare one and get a local engineering firm (assuming you can weld) to weld on a thicker Aluminium pad on the bottom. Clearly it could just be bolted on.
This will only work if it's up to 20 mm or so. Any longer will need a different approach.
I'm not that good with the Brutales and your avatar is tiny on my phone. What year/model side stand are you looking for? This is why people ask you to put your bike in your signature. And some of the later model side stands which are longer are backwards compatible with older bikes and across models.
that's the way i was thinking 20mm should do it .
ok so the 910S side stand uses the same part number as my 1st gen F4's. The 2010+ F4 kickstands are a little longer.
my F4 stand seems way too forward. i hate it and dont trust it. i always put something under it to make it more upright or use unlevel ground to have the bike lean less
I need a longer stand too. Does the GEN 2 kickstands work for the purpose?
Could also make my own if nothing else comes to light.
Yes, I should have been clearer. The 2010+ F4 kickstand is longer and fits the pre 10 F4. I've done the swap on 2 of my bikes.
Take a little of the bend out of the mounting bracket in a press
Or add weldment to the bottom of the pad......I've had to do it twice, I've used the Brutale for a zillion errands:wink2:
1 - 13 of 13 Posts
