1 - 9 of 9 Posts
Does anyone of shorter adjustable clutch and brake levers available for the Brut? I was admiring the Pazzo levers on a Triumph 675 and realized how much more appropriate they would be for me. Any leads?
There are Brembo units with master cylinders....but they're pricey, and I don't think they're any shorter than stock...as they look kinda stock...
Thanks for the input. I will check those out. I was hoping for something more friendly to 2-finger action. I will continue the hunt!
You get the Brembo's and it's apparently more friendly cause it takes 1/2 the effort to pull in the clutch and apply the brakes. Somebody on here has them, and said after install, he wondered if his clutch wa actually working because it was so light/easy to pull in, and now can brake HARD with 2 fingers.
bad part about those? IIRC, they're $500 each...
Radial brake set up.
Brembo and Magura make some for MV! Nice...
Pier, I'm sorry!
That's all I have and it's the only pic I've seen of the Brutale Platino!!
1 - 9 of 9 Posts
