1 - 2 of 2 Posts
I have a Shorai LFX18A1-BS12 from my Ducati 748.
The Shorai sites recommends the LFX19A4-BS12 for the MV 910.
Will the LFX18A from the Duc work in the MV, if I can get it to fit?
If the battery boxes are the same between the F and Bs then it should. I have the LFX18A1-BS12 in my F4 and the length and width are bang on and there is some gap in the height (which is where I store the little tool kit).
You can compare the specs on their store for dimensions. If its smaller then you can use the spacer materials, if its larger no go obviously.
1 - 2 of 2 Posts
