Anyone done a shift lever adjustment? The bottom of the rod is the typical setup (10mm nut, 11mm end), but the top goes into the quick shift unit. It looks like it is a lock nut and threaded end, but it also has yellow paint marking the position from factory assembly so I didn't want to go messing about without double-checking with random strangers on the interwebs
I just need it raised about 1/8-1/4" to change my ankle angle.
