When my Brutale approached it's first service I'm sure (I could be wrong?) that the dash showed "service" and counted down from 100 or 150miles prior to the service milage (ie 600miles). Is that correct or did it count up after it reached 600miles telling you it needed servicing?
Mine is now on 3771 and I know it's due a service at 3800 (and more importantly a new rear tyre!) but I've had no warning come up yet on the dash?
If I remember correctly starting the last 1000km (xxxx miles) it should start counting down.
This countdown can be reset in the dealermenu, accessible by pressing the OK and the SET button together for a couple seconds.
This menu also shows how far away you are from the next service.
My last service, the dealer didn't reset the service odometer and it just states "Service x 0km" or something during the startup process before I start it. When set it did the same, but with x 500km or so reducing down towards the service.
I thought so, mine hasn't come up at all on the dash this time? Something for them to look at when it goes in?
