1 - 9 of 9 Posts
I’ve been in the market looking at F4’s. Both bikes I’ve inspected have the seat cover material pulled loose from the foam. Is this normal? The seat “looks” ok. But when you rest your hand on it, there’s no resistance when you touch the covering. Your finger/hand moves 3/4 of an inch (?) before you feel the foam base...what’s up with that?
This is exactly as you suspect. Yes, it seems to be the norm.
It bothers me but it's a fairly quick/easy fix. Pull the seat, remove staples, 3M spray adhesive, reassemble. Tip: the thin staples go into the plastic seat easier.
Or, as I have, you can just live with it.
Life is too short for puffy seats
Good to know it’s a common condition. Thanks guys!
I would prolly wanna fix that. Not to fond of the “puffy” seat myself, hence the inquiry!
For me....the cleaner/ nicer the bike, the more it would bother me!
for me, I stripped the cover off and recovered it at the same time with Alcantara, much nicer than the vinyl on an MV
1 - 9 of 9 Posts
