1 - 11 of 11 Posts
I did some search, but was no able to find the "O" ring or seal size to use when changing oil, for the oil plug. Thanks for any help.
2008 F4 R312
Um, knowing which bike might help.....:banghead:
The spares list shows a 28x22.3x1 assuming its the sump plug.
All dimensions in mm ��
Dang, I just looked at my resources and cannot find the size. Maybe Noel will chime in at some point.
I would just take the old o-ring to the hardware store along with the plug and match it up.
flyboyaviator;
Are you missing the sealing washer? or do you just want a new one?
Part# 62N015682 is reusable.......it will outlast the bike
22.3mm ID x 28mm OD
:wink2:
@dansoarr: which reference "spares list" did you use? I looked in the parts manual and didn't see the size.
Thanks.
Kind of late for my thanks, that was the answer I was looking for. Thank you again.
flyboyaviator;
22.3mm ID x 28mm OD
:wink2:
1 - 11 of 11 Posts
