1 - 18 of 18 Posts
As I was replacing the low beam bulb on my 910R this morning, I noticed a couple of screws missing on the instrument cluster protector. Can anyone help with sourcing them?
wtf?
hey Mick;
what head style are they? i have a Biondi screen on mine and can't see them......
i'll pull the screen in the morning......PM me an address, i'm sure i have them, they'll be in the Post after Xmas......
next time tighten the damn things:stickpoke:stickpoke
Thank you very much Noel. I can't tell what tyope of screws they are...as they are missing.
PM sent and Merry Christmas
Mick.. they are the same as the ones in a couple of other areas on the bike as shown in the photos.
They are 18.5 mm thread length M4 (4mm) with a thread pitch of 0.7
And they have a 2.5mm hex recesses for your 'allen key'
I lost mine and replaced them with similar 'dome' head replacements not noticeable as they disappear into those 'recesses' in that instrument shroud.
hope that helps...cheers
Brian.:)
Thank you, Brian.
Brian, you sure on the length?
i have a Biondi screen on so i didn't take them out, the ones in the side covers are M4x14
Mick; i'll send them out on the 26th the Post is closed 'til then:drummer:
Thank you, Noel. I won't be back home until the 5th, so no real hurry. Please pm me a cost as well inc postage. Cheers. Michel
Yeah Noel...however the dome head ones I replaced mine (illustrated) with (as I lost the originals) Measure 17.5mm thread length and they work fine.
They go through the instrument shroud as shown and thread in to 'well nuts' in the pressed aluminium instrument bracket. You can see that with the replacements I fitted ...when inserted into those well nuts where they 'begin to thread' there is only around 4-5mm thread left to the underside of the screws heads (for the instrument shroud) So the OEM ones of 18.5mm thread length would be correct. In fact you could maybe get away with a 'little' longer but not 'much' shorter. Hope this helps.
As Noel says Mick, 'Tighten them up'.....I'll take that advice too:laughing:
Happy Christmas Mate:)
Brian.
wtf?
Michel;
cost????? my middle name is Christmas in French, because my Mother got knocked up on Christmas.......one of the few times my parents exhibited a sense of humor:naughty:
Brian;
you want a pair for free too? PM me an address:yo:
Merry Fucking Christmas:drummer::drummer:
and Happy New Year too
mick my 910s is the same
how did you find the wiring a bit short
Michel;
Brian;
Noel., (that's my younger brothers name too by the way)...Yeah of course I'll take a pair of 'anything' if it's goin for free!
Cheers Mate.,
PM sent
Brian:)
in the post!
they're on their way......
you'll find some other stuff in the bubble pack envelope too:drummer:
:friday:
:friday:
Noel, or Christmas, or the forum Santa Claus...
Murky buckets as they say in French.
Thank you very much.
Will let you know when it arrives. I should be back home around the 5th.
Cheerio and all the very best for the coming year! Apparently, you deserve it!
Michel
Col, if you mean the wiring to the headlight, yes definitely tight.
Discussion Starter #15
Thank you Noel!
The parcel arrived today. Many thanks for your help Noel. Now, pardon my ignorance, but what are the rubber O-rings for? Would you use a small one for each replacement screw? I guess I may check other screws around the bike and use some of the small o-rings to secure them? And what are the large ones; for the headlight? Cheers mate and all the very best to you.
ringy things?
Michel;
you're very welcome :f4:
the big O-rings are for the fuel pump plate.....
$11.47 each at your friendly dealer:naughty:
http://store.proitalia.com/advanced_search_result.php?keywords=800090939
the little ones are for the fuel line quick disconnects
a grateful customer brought me several bags of them so i just send them out:yo:
the big ones cost $0.30 from McMaster-Carr the industrial supply house
the little ones cost $0.05
the little ones i send out are 1 size down from the OEM ones, so they won't get cut so easily......and they work:naughty:
Discussion Starter #17
Michel;
Great. Thanks again, Noel.
Noel....I don't buy this 'forum curmudgeon' image at all!.
Thank you so much for the package you sent...I seem to have been the 'beneficiary' of a similar package you sent to Mick. Cheers mate it was unexpected..but very gratefully received!
All my best
Brian.
1 - 18 of 18 Posts
