I have a Scorpion rear stand that I used with my 996 that I'd like to use with my Brutale. I did a little searching on the net but only see two options for the pin, one for Ducati and one for the Honda VFR. Does anyone know if there is an MV pin available, or if the VFR pin will work? As I believe the Ducati pin is too small.....
I had a local machine shop make a pin from stainless steel.
Benjamin St.G said:
Interesting, do you have the specs for the pin still? How much did it run you?
Sorry, no.
But its pretty simple, just take a measurement if the inside diameter of your rear axle. Keep in mind too stay a hair below the actual measurement (otherwise its going to be too tight).
Then measure the inside length of your rear axle.
For the part that goes in the stand, just take the stand with you and have the guy take the measurements himself.
I payed 30 bucks for mine.
Hope this helps!
