1 - 20 of 23 Posts
Sachs shock & Marzocchi forks service vs upgrade
I've never gotten my suspension serviced, but thinking of getting it done on Sachs shock and Marzocchi forks on my 2015 F3 800 (nearing 10,000 km).
A local suspension specialist who is always present at my trackdays told me that I should upgrade the springs in my fork and think of changing the Sachs shock to something 'better'. Is that Sachs shock a bad model??
Is that worth considering? Or is simply servicing the suspension and getting fresh oils in there enough?
Note that for my riding experience, I feel like the bike's suspension is great. But I'm no expert and maybe I'm missing something that I am unaware of??
First thing i would ask is does the bikes suspension give you the feedback and confidence you need to ride at the pace you want safely at the track? if so maybe just a freshening up and spring swap for your weight is fine.
For many of us, a change to the fork springs and valve stack is pretty common (or cartridge kit), and depending on the model and use of the bike, you mentioned track riding, the shock might need a spring and revalving if not replacing.
Sachs and Marzochi are, bottom of the barrel suspension components to be honest. :crying:
First of all, I don't think that's true. My Sachs and Marzochi work fantastic. But to not start a fight and keeping inline with the topic, bottom line is....if your not happy with the setup change it!
Unless you have oodles of money why not try what JDGun said and change out the internals first. Have your suspension friend order you the correct parts based on your goals and also have him set it up for you.
If that doesn't accomplish what you are looking for then look into replacing.
:laugh::laugh::laugh:
You may be right, they may not be the bottom of the barrel ... but you can see the bottom from where they are LOL Some stock low cost showa/kyb stuff is simply terrible.
Well setup stock suspension can be better than expensive high quality stuff that is setup wrong.
With a few upgrade pieces most stock suspension can be made very good and can be setup to work well for the rider.
Look at FG and Andreani for parts/kits specific to your F3's stock components. All joking aside the stock suspension can be made to work quite well. Best of Luck, Cheers
The Sachs shock is junk. Period. There's no point in throwing money at it. The forks can be "made to work" and the ceiling is much higher than the shock. That being said I have a Penske shock for sale .
Sent from my HTC U11 using Tapatalk
It really is about what works for the rider and their intended purpose. hey if your just riding to Starbucks, and zipping along highways with some on ramps, sure the stock stuff is good enough, with maybe just new springs.
If you looking for a quality upgrade I have k-tech DDS Forks and DDS rear shock available With a very recent service, PM me if your interested. John
:mouthwate:mouthwate:mouthwate:mouthwate:mouthwate:mouthwate
Just wanted to add, I had commented about the Sachs shock on a Dave Moss video on youtube (the one where he was testing a JRI shock on his F3 800), and he quickly replied saying the following:
"I rebuilt my Sachs shock (revalve and respring) and it performs extremely well."
All that to say, I think I will try that route (at Race Tech) as its only a $300 affair. I use the bike on the track only but I am nowhere near the fast guys (working on it working on it...) but jesus @dudman, your K-Tech must be trick but sadly out of my budget for now.
Check out Dave Moss, suspension guru, on Youtube. He either has a F3 675 or 800. He swears by the stock suspension and says its one of the best in the business. Don't listen to others when they say it's crap. They either a) have more money than sense or b) looking for an excuse to justify their bad riding. Perhaps get the suspension serviced and get it setup for your weight with riding gear. The suspension has FAR more potential than 99% of riders... especially on the street.
I can understand budget reasons for doing things. But the shock is crap for the track in it's stock form and there's no way around that. A re-valve and spring change drastically changes the behavior and is a good budget upgrade if that's all you can do.
Also IIRC the forks can't be re-valved because of how the internal design is. You're pretty much limited to a spring change.
We can all debate what is or isn't crap on the bike. But i assure you, ride a F3 with quality suspension VS a bike with the stock stuff, and it is mind blowing the difference in the confidence and feedback quality suspension will provide.
As for the statement, well if you have money to blow remark, honestly this bike should of came with FGRT forks and a TTX shock, not to mention an adjustable steering damper for the price they cost. Hell even some Showa BPF or something updated would of been a nice touch.
A shock re-valve and new spring should be top of the list for the track. The extra money blown on new fork cartridge or all-new suspension would be wasted. You're better off spending that money on some lighter wheels and lighter body parts.
:surprise: Bodywork
I think the adreani fork cartridge is about the cheap route on the forks $600, that's what i went with. And they are still not better or even on par with my stock 675R ohlins.
Now that is funny :laugh::laugh::laugh: I don't care who you are that is some funny stuff right there! :laugh::laugh::laugh:
Stock F3 forks are not damped or sprung correctly because the valving and spring rate don't seem to be matched up very well. Basically the rebound, no one is home...
Carts or better forks are not a waste of money. Unless you are such a slow rider that suspension make no difference at all. You would have to really suck or have no skills to believe that.:crying: Changing the suspension to work correctly for a specific rider is the best thing you can do to the F3.:yo: All other changes should be secondary to suspension improvement/optimization.
If the stock suspension with a shock revalve is good enough for Dave Moss then it's good enough for the vast majority of riders.
Getting it setup for the specific rider is a given. It's just not necessary for a cartridge kit or a new shock. Just because you carry the attitude that you're a superior rider doesn't mean you are. An excessive use of emojis isn't helping your case either. Try and be judgemental all you want, it doesn't actually change your perceived level of riding skills.
The fork cartridges cannot be revalved as the compression valve is crimped:
I went with Andreani cartridges made to fit (Italian distributor of Öhlins)
I removed the stock suspension and went Ohlins in the rear and K-Tech DDS in the front.
The shock made a world of difference. The bike now rolls over bumps that used jar the rear end. I’d say an ohlins or k-tech shock is a great investment.
As for the front, I tried an Andreani damping kit and it did a little bit, but not enough for me. I tend to work the front end of the bike pretty hard. So, I ponied up and got K-Tech cartridges. Biggest difference is the front end is now much stiffer. I haven’t had a chance to dial them in, but I’m expecting good things from what I’ve heard from a bunch of pro racer buddies
Sachs aren’t the best products, but if you don’t have a ton of experience, you may just want to try and dial them in, first because suspension ain’t cheap. I’ve got around 4K into mine in parts alone
I also have a set of barely used fork cartridges with the Andreani cartridge kit mounted, for sale. They’re in the for sale section, if you wanted to try that route?
1 - 20 of 23 Posts
