1 - 13 of 13 Posts
It appears I might have a leaking shock. My bike that I just bought is an 05 F4 1000S with about 3500 miles. Is it just a case of time vs mileage wearing a seal out, or are these prone to that? The oil was on the swing arm and its definitely the shock. Am I looking at a "rebuild" or "repair", or may be I just get it rebuilt and setup for my weight/riding style while I'm at it. Next question would be do I trust a local shop to remove it and make the repairs or remove it myself and send the shock off. There are a few reputable shops in the area like MotoCorsa and EDR, but with it being the busy season at these places, I often wonder if they give each bike the time and respect they deserve. Thoughts?
FWIW, I'll be surprised if the oil is over the top of you shock, sure it's not a leaking battery?
If it is your shock, no they don't often leak, yes it's easy to remove, just download the workshop manual. To rebuild, you will have to find someone to do that, you can't do it yourself.
Its definitely oil and it appears to be on the (dripping from) the bottom of the shock, unless its coming from the engine. god I hope not.
If it is your shock and you are in the United States, I would highly recomment Rick Tannenbaum at Cogent Dynamics in Asheville, NC. He rebuilt my buddies shock for his Brutale 910R and he does all of the suspension work on my track bike. His number is 828-628-9025.
You can replace it with a used one. They're cheap as chips.
But, as Marty suggests, if you are going to spend some money, have it rebuilt custom for you.
If CAG has one Daren, please grab it, if not, I have one in the "for sale" section too, but shipping might make it a shitty option. :)
rebuilding gas shocks is just like old shocks EXCEPT you need a nitrogen bottle and injector needle too
best to send it out and have it done for your weight and preferences
:drummer:
Thanks Donsy, when it stops pissing it down, I will take her out again and recheck for leaks, then make a decision.
Downloaded the manuals, thanks very much for that.
(read your website too)
1 - 13 of 13 Posts
