1 - 3 of 3 Posts
The bottom rose joint on the ride height adjuster is worth checking on a regular basis as the recess where is sits just fills up with water with no where to go, the joint on mine is badly corroded but there was no play in it. Worth applying some compressed air to every now and again.
not so rosy....
Shaun;
get in there with some waterproof grease and a small brush...you could heat it a bit 1st too (hot air gun):drummer:
the old 'ounce of prevention' thing
yep it did cross my mind to pack it with grease, as you say prevention is better than the cure...noticed the paint is coming off the sachs rear shocker spring too :(
1 - 3 of 3 Posts
