1 - 13 of 13 Posts
A great improvement over the OEM mirrors on my Brutale 1078rr is the Rizoma Limit mirrors.
Great though they are I made a small improvement the enhances them greatly.
I machined a couple of 19mm x 20mm aluminium 'spacers/extenders'
(you cannot make them any longer than 20mm as part of the articulating mirror arm then hits against the throttle cable metal adjusters).
Anyway it's a very simple..., but effective improvement.
Brian:)
Looks good. Now you just need to send them off to the anodizer if you want to be real picky
Discussion Starter · #3 ·
All in hand:).....and I reduced the overall length to 18mm to avoid that 'clash' as mentioned above.
Brian.
Nicely done Brian. I've got the same mirrors, but in silver. A great improvement over the wobbly glass originals! I'm now considering doing this to my Brutale.
Dave.
I was going to do something similar but instead of making an extender piece I was going to make an extended pivot linkage.
How much of an improvement is the view from the mirrors?
Discussion Starter · #6 ·
Dave.
Go for it guys..., it 'IS' an improvement (not perfect)....., but it does project the mirrors 18mm (3/4") further out past where they were ........that is 18mm less of your elbows in vision:smoking:
And as they say about Tesco's...."every little helps":)
Hi Brian
these extenders look perfect. What was the finished size ? 18mm long and 19mm overall ? how big hole ? M6? did you need a longer bolt?
thanks
Discussion Starter · #11 ·
Hi Brian
thanks
Thanks Mark...,the finished size of those mirror extenders I made are..;
18mm long
19.5mm diameter
6mm hole.
M6 x 35mm bolt length (shank)
Hope this helps
Brian.:)
Following on from @BG Wells mod I also added a spacer but increased the spacer length to 25mm on the 1090RR (good advice taken from @bogie).
Makes a world of difference. Can now see past my elbows without any issues at all.
Used
Spacer - 25mm length 20mm o/d M6 hole
Bolt - M6 45mm shank length
Reactions: bogie
1 - 13 of 13 Posts
