Bike shuts down, warning lights are battery and oil. Oil sump is full. Was riding for about 20 minutes so battery may not be charging.
All lights turn on then off, now both are staying on.. checking fuse in 15 minutesGlenn;
you have the red battery light before it shuts off? or after? (which is normal)
check the 40 amp fuse....
Was doing 100km plus temperature was up in 90's.Is the bike idling OK?Is it stalling when you are gearing down coming to a stop?
Sent a messageYou must have a multimeter,you have already checked battery voltage with bike switched off,now check voltage at 2000rpm,what have you got?
Didn't look, sent to service it before I got it 3 weeks ago it had been sitting 2to 3 yrs so changing all fluidswas the 40Amp fuse good?
Mitch;In that case it could be as simple as bad fuel.![]()
