1 - 3 of 3 Posts
hey guys, question for you guys, my mv sits soo high i can barly reach the ground, and the height adjusment is all the way down, if i readjust my chain and turn the adjusment hub untill the bike comes down and the chain is still adjusted to proper value, will this work?
My sugguestion is boot with a thicker sole. You could probably play around with the front and rear preload but I think that will ruin the handling.
Also, what size is your rear tire? I think the '05 had a 190/50 while the '06 have a 190/55.
You could remove the linkage, mill a millimeter or two off one end and put it back on. I don't know if this would effect the handling or not. Most folks believe it would.
1 - 3 of 3 Posts
