1 - 3 of 3 Posts
Has anyone got a race ECU for a 312. I have purchased one and had it fitted. Chris at X-bikes said the numbers on it were not the same as the ones on his superstock bikes.
I wondered if the ECU I have is only for rear cans and not a full system. It has switched the lambda sensor off.
Any numbers or ideas would be appreciated
Clive
What I was told is that there is a single part number for the RG3 ECU, but there are several variants depending on what map is flashed into it. Mine has the machine-imprinted sticker with the following written:
IAW 5SM.A0 F511
HW 400/8014-CA01
5ZDH5RH4H 12V= 107 07
Then it has a smaller sticker at the bottom edge of that with the following hand-written designation:
F4 312 RG3
Hi thanks for the Info my numbers are the same except for the last set mine reads 52DHLT16H 12v 169 07
I wonder what it refers to? If you dont mind me asking where did you get yours from ? and are you in the UK ?
regards
Clive
1 - 3 of 3 Posts
