I don't know if they carried that over but it's easy to check. The diode is accross 2 wires on the connector of the main power relay. It's the one with the main fuses. If it has the diode, and if you're lucky, that and the fuse is all that needs fixing.
I'm sure someone with F3 knowledge will be along shortly.
