Hello everyone, I am the owner of Brutale 800 RC 2018, did anyone change the gears like moto gp down 2,3,4,5,6 and up return? I'm waiting for the holidays and what changes are involved, thank you.
Not 100% on the Brutale, but normally you would reverse the arm on the gear selector, that's the basic mechanical change. However your quick shifter will be backwards. So you either need to turn the quickshifter sensor around, if possible or switch the positive and negative wires on the sensor. This means that the sensor output sensor will react correctly. Or if you have ECU Studio, just select revered on the shifter direction :)
Welcome to the family @Brutale Reparto Corse.. !! What he said ^^^^.. !!!
Please make an introductory post in the "New Members" section, and add your location on the planet to your profile.
Ah, I totally forgot about the frame issue. For reverse shift you will need to get a replacement footrest or gear lever. Quite a few manufactures do them.
478493
