CAG or Spartakus should jump in here. I believe that was the problem we found with Dan's bike.....
I've heard there are 2 diodes on the 07 F4 Senna 1 I've replaced (starter solenoid) does anyone know where the second one is?
I looked everywhere under the seat and couldn't find a second diode. Is that schematic for a F4 1000 Senna? The bike will only push start no electric start. I have also replace the starter solenoid and starter relay.
It's a 1000 Joe, halloooo......Hi,
I went to manuals and 750 electrical system and that's where i obtained that information. It is a part of the wiring diagram.
I don't know the 750 as i have a 1000 312R, Maybe someone with a 750 could chime in. The diode could be under the outer insulation of the bundle coming from the general feed relay which I am guessing is the one on the right side of the bike under the tail/seat unit.
Have you got a multi-meter ?
Use one to check through the starter circuit
Best of luck !
joe
If the bikes runs when pushed, then it's not any of the safety switches, it can only be your battery, starter solenoid or the actual start button.Mine is the 07 1000 Senna....I did read that thread but with mine everything fires up, fuel pump primes, guages work, just no starter. When pushed it runs perfectly. Battery is perfect, diode replaced, starter solenoid replaced, and relay replaced.
the results of electronic fucktards designing things ChuckLooking at the wiring diagrams for the three versions of the 1000, the 1000S has the second diode across the General Relay (the diode looks like a wire to the uninitiated), the 2006(7?) Senna has a diode across two wires in the Starter Relay, and the 2007(8?) 312R has a similar set up to the Senna WITHOUT the diode across the Starter Relay.
Curious.
Spot on Chuck, I've noticed this before and asked the question, but nobody came back with an answer. I got a wiring harness from the UK which was supposed to be from a 07 1000R and this has a diode on the relay as is the case with my 06 1000R harness.Looking at the wiring diagrams for the three versions of the 1000, the 1000S has the second diode across the General Relay (the diode looks like a wire to the uninitiated), the 2006(7?) Senna has a diode across two wires in the Starteer Relay, and the 2007(8?) 312R has a simialr set up to the Senna WITHOUT the diode across the Starter Relay.
Curious.
If you can't hear the relay kicking in, that's the next thing I'd check.Only diode on mine is on the starter relay, starter works when given 12v directly. Starter switch is the next trial. .....
When I however modified the UK harness, I found the wiring colours to match those of a 312R as per manuals. I assume that the diode was left out on the drawing as Noel suggests.
Next time you fiddle with that beast of yours, please check and let us know if possible please ?
