1 - 2 of 2 Posts
Can someone do a walk through or explanation on how to remove the plastic spacer on the front blinkers (between the lamp piece and the mounting spot) and then reattach the blinker to the bike?
You have to buy a shorter shoulder bolt. Just remove the headlight and you will see the bolt, then take it out, take it to the hardware store and buy one that is shorter by the length of the spacer, then reinstall sans spacer.
1 - 2 of 2 Posts
