Is there anyone who produces a replacement top triple clamp for the Brutale? My winter project is to replace the handlebars with a set of Rizoma's and to either replace or powdercoat the top triple clamp black.
It's for converting an F4 into a street fighter, pre-Brutale, essentially a Brutale :p
You might have to cut off the steering damper tab, but I'm pretty sure it'd still work.
It's from:
http://www.mvagusta-parts.com/e_startseite.html
Thanks! Possibly an option. I will send over an email to check the removal of the damper tab and adding the forward tabs for the instrument cluster. If he has gotten that far he might be able to change the machining slightly enough to accomadate a couple of adjustments. Has anyone ever compared the clamp to that of a Monster? Speedymoto makes some great stuff just nothing really for MV's. Has anyone in that area approached them about expanding the catalog to MV?
