Replacement Springs for Marzocchi Forks? (Help)
Can anyone tell me where I can get some springs to fit the Marzocchi 50mm?
I have the MV SPR and I took it to a suspension specialist here in Northern Cal to get the suspension tuned. I weight 155 lbs so I was only getting 20mm of sag. I was told that in order for the suspension to work at it's best I would need springs to suit my weight (.80 kilo to be exact). He could not find springs to fit these forks.
Does anyone have information on where I might be able to get springs for the Marzocchi forks? Has anyone run into a similar situation?
Any info would be appreciated.
Thanks, Dominic
The good intentions behind posting the above link are there for all to see, but I find it amazing that you can have such detailed claims from some manufacturers/distributors without actually stating any technical specifications.......errrm, for example spring rates would be handy for replacement springs (not that I'd know what to do with them!).
My favourite - "special polyester surface". I think that means blue paint.
Goto a KTM dealer if there's no MV dealer around. MANY KTMs have 50mm Marzocchi's on them, so those guys will know those forks through and through...
