1 - 6 of 6 Posts
2005 F4 AGO 2017 TVL RC
Does anyone make an aftermarket master cylnder that has the mirror mount like the stock part
Discussion Starter · #2 · (Edited)
since no one else was kind enough to answer my question I will. Beringer makes a master cylinder with built iin reservior and a mounting clamp with mirror mounting hole. So there. :) They ain't cheap
Nissin makes a radial master cylinder that comes with a mirror mount. It doesn't have an integrated reservoir, though.
Formerly known as Lumiator
Brembo and Motocorse
If you choose this combination keep in mind that the Motocorse mirror holding clamps do only fit to the Brembo radial master cylinders and not to the Brembo RCS master cylinders.
I was not when buying them, so 2 additional good looking MC parts are taking some room in the showcase. :)
Here the Motocorse codes of the mirror clamps:
104147029 (clutch)
104147027 (brake)
1 - 6 of 6 Posts
