How do you guys remove the EPROM chip from its position in the ECU?
The guide in the MV FAQ mentions using an plastic EPROM removal tool, but I have been unable to source one locally at 2 supply stores, and I'm wary of trying to prize it out when I'm not sure of how much pressure is required.
What sort of supply stores have you tried?
I got a ceramic one from an electronics store. It was only a couple of dollars.
Ball & Chain magnet
careful not to touch the edges of the ECU housing as it may short out and you can say "bye-bye" to that eprom chip.
Best thing to do is disconnect the battery before you try anything.
is there a certain time limit to get the battery connected again? i can vaguely remember reading something about it.
Medium sized vise grips set for a gentle grab.
mmmm vice like grip or grip like vise...
I remember an early girlfriend used that type of anomality - but that was a long time ago !!:toothless
Rents - I tried Dick Smiths & Jaycar without any luck.
I touched the edges of my chip and it was fine, only when I put it in the wrong way did it short out:banghead:
