1 - 2 of 2 Posts
Hi all
I have been trying to find the way to remove the plate support from
my F4 1000R, I am used to remove it when I go to tracks, but so far my Brutale plate support has only three screws and it takes 2 minutes.
But the F4R when I lift the seat I got surprise of the amount of connections and stuff all perfectly organised....So I prefered to ask here in the Forum and see if anyone can assit me on this.
I have also seen several screws but they are not so easy to reach without removing something else....but I doubt whether to put my hand on something else that i do not have a clue of what it is.
Is there anyone that could help me ??
regards
ZAR
You have to remove the four nuts that hold down the ECU and lift it out of the way. The three bolts for the plate bracket are below that. It's easiest if you also unbolt the bracket that holds the two halves of the exhaust endcans together. This allows you to slide the plate support out easier.
1 - 2 of 2 Posts
