1 - 10 of 10 Posts
Would anyone know how to remove the Italian gel decal on either side of the air ducts? I was thinking about getting some carbon one's and want to re-attach the decal, cheers :flash:
don't be cheap...just order what you need from dealer. Decals are the one thing that are easily available.
They just peel off. It helps to heat them up a bit first. Just leave the bike in the sun for a bit and then carefully start to lift them up at a Corner and remove.
Those cheap decals are about £30 each :jsm: I was going to do the same thing, be carefull not to bend them too much as the flag cracks and is visible through the clear gell :)
1 - 10 of 10 Posts
