1 - 9 of 9 Posts
Good idea. Describe a little more the modification.
Discussion Starter · #3 ·
rear fender eliminated and oem rear signals reversed and attached with 3m double sided inside tail behind vents
What will you fabricate up for the license plate and plate light?
Discussion Starter · #5 ·
plate bolts directly to mounts under exhaust but i will be installing a qd exhaust so we'll see if theres a difference in the mounting position for the plate
I did the same thing on a Ducati 996 and put signals behind the tail vents. I connected it to the subframe with a strip of thin sheetmetal wrapped around the frame and drilled a hole at the ends for the light screw to go though and tighten. Essentially it was a clamp and light holder in one.
looks good, but hasn't this been tryed before and caused heat damage to the paint? or was that because they blocked the vent off all together ?
I think they are LED`s which put out nominal heat.
Dd the same ,first day I got mine ,it's led no heat,my 05 have the same thing but some LEDs ,working good tell now
1 - 9 of 9 Posts
