1 - 12 of 12 Posts
My SPR has been poorly treated by its previous owner so I am in full detail mode.
My question relates to the RG3 system, I want to have the Titanium pipes back to the straight off the floor look, atm it is road worn with bits of tar/rubber and slight weather degredation.
Is Titanium ok for me to steel brush this stuff off with, will I damage the metal by essentially taking a very light layer off the top?
I was planning on bying a brush tip for my drill and doing the whole system.
Thoughts?
dirty Ti ?
i'd remove the pipes to clean them
a wire brush will leave a very uneven finish
1. try spray on engine cleaner with a nylon brush
2. media blast
3. finally light glass bead blast if they are really dirty
since Ti doesn't corrode, my bet is that engine cleaner and the brush will do the job :drummer:
:f4::brutale:
Get some "metal Prep" or other such metal cleaner. Has phosphoric acid in it to etch metal before painting. It'll clean all that crap off and not harm the metal or the finish.
Never use a steel brush or wool to rub down Ti., Al., Mg. etc. The steel will imbed then you'll see rust starting to appear after a few days, and you can never get the stuff out after its in there. That is unless you take a hone or something like that to it and take off the top layer of metal.
+1, No steel wool. I used mild dishwashing liquid and scotchbrite on my ti akro's and they always came up a treat. Dont scrub too hard though. You may be suprised how easily ti cleanns up.
Don't use a wire brush. Start with something in the detergent or organic solvent (acetone, degreaser, kerosene, etc.) category to get tar & grime off. If you clean it really well with a detergent solution and acetone and it still looks dirty, you'll need to use something corrosive to take away the oxide layer. When some chemicals and oils are left on the pipe when it gets hot, it can change the rate of oxidation on the surface, permanently changing the color and making it look dirty forever. Don't start with metal prep or other acidic chemicals. If you put the acidic stuff on a dirty surface the result wont be uniform.
i refinished the raw frame on my Ti bicycle with just water and a scotchbrite. Doing it that way will add a brushed finish however, so you'd need to pick a direction for the grain to flow and continue that way throughout. Agree with everything already said, no steel brushes, start with some mild detergent first and work your way up to the heavy stuff.
Thanks for all the advice guys,
In answer to CAGS question, i have the RG3 baffles, i thought the entire system on the SPR was a standard Ti item?
As i bought the bike second hand I am unsure of all the previous mods made, I am also wondering now....... is the RG3 component simply the baffles and tips?......and from the baffles to the exhaust manifold another metal?
The RG3s are stainless steel. They came with the bike in addition to the stock exhaust. You can use almost anything to clean stainless. If the heavy crud is greasy, use some engine brite or other heavy duty degreaser. I would finish cleaning them with Never dull.
Thanks CAG,
I must have my wires crossed, I thought the SPRs system was a Ti job.
All good though as now I can get to work bringing her back to show status.
I have just finished fabricating some rear sets that show off the exhaust a bit more than the standard ones did, I will post some flicks once my camera is back in action.
Cheers.
Thanks CAG,
Cheers.
So you going to offer up your oem rearsets?
1 - 12 of 12 Posts
