1 - 6 of 6 Posts
Has anybody removed the rear wheel on there 910. I cant beleave it only 600mi and i got nail right in the center. going to have it fixed on saterday. A place in the san fernando valley mid valley tire says they can fix it if i bring them the wheel. any body no the torque on the rear wheel the book says 220-224 Nm How many pounds
220 - 224 Nm is 162 - 165 Lb/ft ...
Easy to remove is you have the rear wheel nut tool.
Where are you in the SFV ?
Care if this is the first time the wheel is being taken off, the wheel nut is very tight from the factory, and needs a good amount of initial 'cracking' to remove it...
Just read in another thread you are in Northridge. I work in Woodland Hills. If you need help or need the tools, I can drop by one day.
I had my girlfrend sit on the bike when I remived the nut and she and the bike got picked up befor the nut popped loose. Don`t forget to remove the spring and bolts that hold the lower slipon and swing it out of the way. Good luck,Chris.
1 - 6 of 6 Posts
