1 - 12 of 12 Posts
Has anyone done this swap before from a 2012 bolt less carrier to a pre 2009 bolted carrier.
I find the bolted carrier is a better design and less movement.
Rick;
shouldn't be a problem.......I'm using >10 swingarms with Mitch hubs and the early cush
drives
you must use the shouldered spacer of the new hub not the old 2.0x76mm flat washer
:popcorn:
1 - 12 of 12 Posts
