Ok I read thru the search files. I can't get the rear wheel loose. I have an impact driver,@ 90-psi 250lbs-ft. setting my compresser @ 145psi I should have enough force to remove nut. The nut is not moving. 240NM is 176lbs-ft I think. What do I try next???:stickpoke
To remove it is clock-wise. That is the direction I have been turning the nut.
New Impact Driver
So the problem was not enough torque, out of my impact driver. Never send a woman to buy tools. Tossed the $25.00 CP Impact driver in the kids tool box, Harbor Freight special. Bought a Ingersoll Rand 1/2 Impact Driver. 780 LBS-FT The nut came right off. All threads look good, so do I use oil or antiseize??? New 2CT already mounted. Thanks John
