Just got Carbon fiber Hugger of Ebay looks good but would like help with fitting info. Hugger has 3 holes in same place as bungs in swing arm what kind of fittings are used in the swing arm holes to attach hugger?
I have 2006 Brutale 910s
Lorne
Get the seller on eBay to send you the two screws. You use the existing chain gaurd screw and a small screw with plastic expander (whatever those things are called) that goes in that triangle section on the left side of the hugger. You will need to remove the rubber grommet that's in there now.
On the right side there is a larger screw with a cube shaped expander.
If you don't have these screws supplied I think they'll be a bitch to find at a hardware shop.
The seller should have supplied them.
By the way that's not my bike. It's MV Rob's. He just happens to have good pics of his hugger in his gallery. Really nice bike too.
Visited local MV dealer had the rubber backed well nuts all is well thanks for the link to the thread
Lorne
