1 - 3 of 3 Posts
I have a `06 910R that I bought new. It has 10K miles on it and I need to look at the rear hub before spring. I have had no problems in this area and would like to keep it that way. What is it I need to do? I assume a total disassembly of the hub, clean and relube? Shpuld I pre order any parts? Thanks
No need to replace anything (unless you note rough movement or looseness in the hub when you have it on the stand).
Follow the manual.....disassemble, clean, grease and reassemble. If you take it apart and find everything looks great and grease is clean, just add some more grease and put it back together.
Put it back together carefully maintaining the torque specs....
1 - 3 of 3 Posts
