Hi There,
I have noticed that the rear gear flange support (no 27) is a little sloppy on the gear flange (no 37)... is this a case of getting new gear spring drive's (no 30) for it?
PS: did i get that right? LOL
Simon
Yes...those are the drive line damper cushions that absorb the hit when you yank the front wheel into the air.!!!
Thanks for that.. looks like i need 5 of them correct?
Does anyone know the best place to get these from?
Hey G..
I imagine the all mighty CAG will probably have something :)
...did you order your new SPU ?
Hey G..
Cheers for that...
SPU: They had one in stock here in NZ would you believe! Only about $100 bucks more than if i had ordered it from V. It arrives tomorrow, so lets hope that its the right part. Fingers x'ed, touch wood.
The dampers in the sprocket carrier are wear items. Inspect the carrier they fit into for damage if they have been moving a lot. Recommend buy new as used will be worn. Yes, replace them all at same time.
About NZ$70 per damper!
