Hi community, i recently have a problem with my rear brake( BACK BRAKE) stop to work, in the agency they told me that they have a warranty for this problem, the solution they told me was to replace the brake fluid for a MOTUL RBF 660.
My bike is brand new 2019 year and 3,900km, anyone else have this problem yet?
i read your comments.
THANKS!
Common issue, lots on the forum about it.
Wing Nut
MV has a Service Bulletin about this. That is what your dealer is referring to. So the dealer should perform the bulletin procedure with the new high temperature brake fluid prescribed...and I believe it should be covered under the warranty, so no charge for you.
Wing Nut
Do a "Search" for "no rear brakes"...you will get many threads to read from.
THANKS!
Hi Edgar,
I'm having a rear brake issue on my new (ish) TV...
What was the outcome for you?
Did the dealer fix it as a warranty item or did have to pay?
Thanks,
Michael
Yep, what your dealer already stated. Go for that.
I've had it done twice at my dealer. First time was a no-go after som weeks, but we'll see now. Apparently they used an even better braking fluid this time.
