1 - 15 of 15 Posts
I had to replace the tires on my 2019 Dragster RC a few days. I took the rear wheel axle nut off with a impact gun.
I tightened the nut to 170 nm ( my torque wrench does not go any higher) and this is how far off the witness marks are.
There are also two witness marks on the rear axle nut ( the two yellow marks on the left).
I rode the bike to a ducati dealership to so they could torque the axle nut to 220 nm but the witness marks are still pretty far off.
They backed the nut off and then hand tightened as much as they could then applied the torque wrench.
Not understanding how it could be this far off.
Where did you apply lube/neverseez?
Reactions: esq'z me
None on the angled face, right?
Probably, you didn't install the rear wheel in the same position has it was before. You can install it in three more diferent position.
Do you know that the nut was correctly torqued when the witness marks were made?
I think @Panchomeneguzi and @Akorenika have it right. The wheel can index into several positions on the axle. The witness marks need to be on items that don't change in relationship, i.e. the axle and the nut.
I figured they were from the factory. Anyway I torqued the wheel to the proper torque. It should be all good.
Those marks are from the factory.
What I'm saying is this. If you want paint marks that line up again ( I don't by the way) you can't use the rim and the nut as the rim can go on in a number of positions. What you can do is mark up the nut and the axle.
1 - 15 of 15 Posts
