I have a mv brutale800rr from 2015 with a diagnosis square 4pin plug + / - and canbus high,low.
The ECU is from Eldor NEM0A8.
I can get in the ECU with the normale ELM327 vgate icar2 BT3.0 for reading it out.
Is it possible that the ELM327 odb2 with pic 18f2480 and ftdi chip without switch will work.
Have someone any suggestion for me.
Thanks if got a good answer.
Silvain
Welcome to the family @Silvain Where on this planet are you located? Would you please add that to your profile?
Make 2 more posts here and you will be able to post in other more appropriate sections with your questions.
You obviously are more conversant in the reading of ECUs than I am, so I can't really help you with your question....but I am sure someone else can.
As far as I know Eldor ECUs cannot be read.
You can only write them.
ECUstudio has all the OEM files and you can write with their Software.
Great product 👌.
Thanks for the information
Where can I find the oem files.
The real elm327 still not find to get in the ECU for write it.
The mv800rr get not enough fuel at low rpm
Was Luca able to help?
