1 - 20 of 22 Posts
Hi guys:
Well...after a time with this idea going around my head I've decided fix back the original exhaust, even loosing that amazing sound. The reason I do it is because, I really love the look of the original ones. Now I have to remap my PCIII for the new configuration. I been looking on powercommander.com for a map that would go fine for an Arrows midpipe but I can't find it. All it is is that could work is the zero map and European Model Stock Exhaust Stock Air filter Stock EPROM.
Is there any other posibility? Do you think European Model Stock Exhaust Stock Air filter Stock EPROM will work fine?
THANKS IN ADVANCE.
FERROMAN said:
Hi guys:
THANKS IN ADVANCE.
With my little knowledge regarding the PCIII and discussions I have had with qualified mechanics (who map them) as well as the reading up on the product; I believe you will have to take it to someone experienced in this area to re-map the fuel system, please let me know if I am wrong but I have heard that if you start changing exhausts around you wil need to re-map. Unless of course you have the original map from when you had the original exhaust.
Actually the original map is as simple as setting a zero map, but I wonder if there is the chance of getting a map for JUST THE ARROWS MIDPIPE...maybe the zero would be the closest I can find, but then...WHAT A WASTE!!!!
Yeah, I am not sure what you can do now.
I haven't seen anyone post that they've swapped just the midpipe AND done a map. Besides, it could still be way off from what your bike needs. If I were you I'd consider selling the PCIII and just running stock. From what I've read around here - haven't tested mine - the Brutale tends to run rich so the midpipe should lean it out a bit and be fine.
But then, I've seen a lot of Brutales have their pipes turn very blue...which is normally a sign of overheating due to a lean condition. So basically I know nothing and now I'm posting for no reason. Sorry if I'm no help.
That's a posibility. But before I take a desition I want to be totally sure. I need Airfuel advice...AIRFUEL WHERE ARE YOU!!!!!! :ahhh: :ahhh: :ahhh:
airfuel said:
The bikes vary greatly. Only way for sure is to get it on a dyno with an A/F sniffer.
Upsss...you're quick man :eek: . So I asume there is no specific map for this combination :bawling: , right?
Thanks.
Even if there was a map for that combination, it might not work. (good)
The Italian bikes with the trim screw in the computer, TPS settings, air bypass settings etc, make these beasts very different. Call it character if you'd like.
You could try different maps, but getting one made is the best bet.
I have an 04 with the Arrow mid pipe, stock pipes (love the look) and a PCIII also.......currently running the map that came installed with the PC. The bike still is a little hesitant coming off the line and still pops a little when slowing on a closed throttle :(
I was hoping to find a map, i could try, from someone who has the same configuration. If it doesn't cure the problems, then i guess it's custom map time.
Mako
04 Brutale S
02 RSV-R
90 FZR 400
I'm in the same boat as both of you. Just had a arrow midpipe installed and a PCIII installed. I will get it dyno'd and tuned as a last resort if not happy with the canned maps. I get the bike back tomorrow and will let you know what's up once I have taken it for a ride.
That would be a great help. Let us know your impressions. If you dyno, I guess you'll make a personal map for your bike, but it definitly will be better that the "standard" maps on powercommander.com (or maybe not).
Can't wait for your answer, Thanks.
Well...I finally took my bike to the dyno, and what a disappointment!!! The best way it goes with the combination we have is the zero map. So what a waste of money!!! Did anyone made a map for this combination? Otherways I think I'm selling the fu*@¨ng thing away. Any news Brutish?
Forget downloading a generic map. The only way & the intention of the power commander system is to custom map the thing. This will provide the results you are after.......given that your tuner know's what he is doing.
Ferroman,
Tell us more about your visit to the dyno shop.
Were you comparing generic maps?
Was the shop a PC tuning center or just a dyno shop.
Wide open pulls??
What about part throttle?
Show us graphs with the a/f ratio.
Ferroman - sorry for the delayed response. I got my bike back from the tuner (evoluzione is simi valley), who installed the arrow midpipe and a PCIII for me. He did not dyno and I told him to just use the PCIII stock map for now. It's not perfect, but was a pretty substantial improvement over where I was before. Granted, I just had my first service done as well, so it is hard to isolate the cause of the improved performance. The main improvement has been near total eliminate of the herky-jerkies when rolling on the throttle in first gear (this was my major complaint). I would still like to do a custom map - but I am very pleased for now. So sorry to hear about your unfavorable experience. i think I may have gotten lucky here. If/when I do a custom map, I will definitely send you the program to try.
1 - 20 of 22 Posts
