1 - 2 of 2 Posts
I tested the rad cap on my 2010 F4. Its leaking at low pressures into the overflow tank, not from the main filler... Are these caps a universal type cap ? Can I pick one up at a auto parts store ? Or are they specific to the MV only ?
The 2nd Gen radiator caps are 45mm caps......but because engineers are ASSHOLES ......there are different lengths of caps
you need​ to match the distance between the gasket surfaces AND the pressure rating stamped on the cap
:wink2:
1 - 2 of 2 Posts
