Hi all new to the forum. My problem is with the f3 quick shift its fine riding around at low revs, but if I'm riding at a higher rpm and change gear it's like it goes into neutral for a few seconds. I have been reading for hours now and can't fined a solution. Can anyone help. I have fitted a brand new q/s and it's still the same.
Thanks Jamie
Welcome! Is this an aftermarket quickshifter or a MV Agusta quickshifter that you installed?
Just a few things I did for mine to work fine.
Did you adjust the gear lever to the right position to make sure you can click the gears fully upwards?
Very important, you have to click the gears up hard and all the way up, else it won't work.
Do you hear the quick shifter working, i.e. lowering the rpm?
Keep accelerating when changing gears upwards and do not touch the clutch.
Around 7000rpm and above works best.
